Page 1 of 2
Knackered Rapido - what are my options?
Posted: Sun Jul 26, 2009 1:50 pm
by Dazza
I stripped my top end down today following problems on the way to darlo yesterday, for the second time in a week the rings have snagged on the exhaust port and buggered the piston and scored the barrel.
I don't know if the scores are too deep to rebore past, my initial thoughts were - rebore and racetour piston ( £140.00 for the piston alone ) which will cost more than a new kit which are £185.00 .
I guess i need someone to look at the barrel first to assess if it's useable.
Does anyone have any reccomendations as to someone that I could trust to carry out a rebore a to the correct size for the new piston?
Any other ideas?
Re: Knackered Rapido - what are my options?
Posted: Sun Jul 26, 2009 2:19 pm
by shocky
there is obviously some fault with the barrel or piston type id take it somewere other than were you bought it and get it inspected then armed with thae info take it back to were it came from explain the problem and back it up with the relivent info also give them a copy in writing of the problem and await there respone give them a time limit for this again in writing ,be nice polite and calm telling them what you want done about the problem if there is one ,if you get no joy contact trading standards for your redress, also do other scooterists a favour and tell us the shops reply wether its postive or negative cheers steve
Posted: Sun Jul 26, 2009 6:18 pm
by goldeneye
thing is shocky, like most motorcross shops etc... no garaurntees on a tuned motor, and as the dealer in question, AF rayspeed do these kits, hasnt supplied the replacement piston, or set the scooter up, i"m afraid he wont have much comeback. if you bought a set of pistons from , say , a vauxhall garage for your astra, and didnt get them to fit them, then it went bang, what do you think they would say? not judging your engine building prowess Dazza.. but running in on th A1.....????? is it a 225? you"ll have a couple of oversizes left. if a 200, loadsa opportunities. race tour piston, suzuki TS250 piston on an APE conrod, clean your ports up and put a proper ASSO piston in. loads really... dont worry man. just get it measured up properly and dont just stick another piston in. Rapidos are good kits when fettled properly,and i know of a good few that really FLY!!........... dont get dis-heartened daz. but get it measuered up, and sorted.
Posted: Sun Jul 26, 2009 7:11 pm
by corrado
From what I recall it's a 225 and the piston and rings did come from AFR.
Posted: Sun Jul 26, 2009 7:16 pm
by Dazza
Yeah , with hindsight the A1 was a bad idea
I dont plan on seeking compensation for the pistons - although both failed in the same place - around the exhaust port area, both were Escorts pistons and both were from AF so I may just phone them to let them know.
I think I am going to nip over to MB ,let them have a look at the barrel, if they reckon they can clean it up, I'll go for the racetour option and run it in gently
Posted: Sun Jul 26, 2009 7:18 pm
by Andy Pickering
Im looking to go down the ts250 suzuki route with a knackered rapido barrel so you could do just that dazza.
If you replace the kit with something else dazza id be intrested in the barrel..
..hope that doesnt sound a bit vulturish didnt mean to.
Posted: Sun Jul 26, 2009 7:20 pm
by Dazza
If it's deemed unuseable then I'll give you a shout - you vulture
Posted: Sun Jul 26, 2009 7:26 pm
by Andy Pickering
Dazza wrote:If it's deemed unuseable then I'll give you a shout - you vulture
...could you not just get a liner put in it
Posted: Sun Jul 26, 2009 7:32 pm
by Dazza
I suppose so, I'm not sure how this and a new racetour piston would compare to the price of a new rapido kit though?
Posted: Sun Jul 26, 2009 7:38 pm
by goldeneye
if its any consolation dazza, i went to the cumy 3 TIMES over the weekend, to drop stuff off, put tents up, had to go to work till ten pm on friday, then went back over to see our lass who went there on the tea-time, then tent down, over to whitby for a party saturday (still in a tent!) then back over to darlo this morning to pick stuff up! punctured back tyre and 230 miles for a local rally i had 2 pints and 2 cups of coffee at! apparently it was reet good, with only a handfull of cars for the staff...........500 peeps, and two pubs in the village drank dry....... and a jack the ripper on stage!
and everyone laffing and carrying on this morning! mind, i wasnt playing this year...... probly why it was so good.....
get it measured eh!!!!!!! dont give up!!!!!!!!
