Hi Comp issue
Posted: Fri Aug 04, 2023 4:44 pm
by stevescoots
Finally installed and started up my 230 pinasco build on SS180 block. Runs really well..but..compression is so high it’s a nightmare to kick off and even bent my MHR stand plate trying! Squish is 1.8mm as recommended. 2 choices I see, either have the head reprofiled or drill a decomp hole above the exhaust port. Anybody done this? seen them done on Lammy kits. Or is there a 3rd option?
Engine is built for touring set up. SS180 gearbox with BGM 23T clutch. 28 mm SI carb, 2kg Atomic flywheel and Sip 3 box
Re: Hi Comp issue
Posted: Sun Aug 06, 2023 8:17 am
by hendy
I'm not familiar with vespa motors, but an often disregarded aspect is the gearbox ratio.
As capacity increases, you can usually lower the gear ratio, which (in the case of lambrettas), has the same effect as a longer kick-start.
Maybe your 23t clutch has already done this?
