Sip vape problems
Posted: Mon Feb 06, 2023 11:24 am
by boxofbits
Sip vape problems
Just been for a spin on Sunday –only got 2 miles away and it just died-
Bike started still first kick but just will not pick up off the clutch just stalls, had carb in bits can’t see any problem there –
Left it for 10 mins seems ok again- but did it again-
Feel like a CDI problem
Do the CDI go on these- stator reads ok—but no way of testing the CDI ( unless some one knows I way)? :oops:
Re: Sip vape problems
Posted: Tue Feb 07, 2023 4:41 pm
by Toddy
boxofbits wrote: ↑Mon Feb 06, 2023 11:24 am Sip vape problems
Have you got good earths fitted these are crucial on the vape
Posted: Thu Feb 09, 2023 1:36 pm
by boxofbits
I've earthed to the frame but my mate says I should earth to engine does it matter?
Posted: Fri Feb 10, 2023 9:19 am
by Daggs
Have you considered a petrol tank cap breather blockage. Or a petrol tap blockage?
Posted: Fri Feb 10, 2023 9:21 am
by boxofbits
No will check that tomorrow- am- and report back
Posted: Fri Feb 10, 2023 9:30 am
by Toddy
boxofbits wrote: ↑Thu Feb 09, 2023 1:36 pm I've earthed to the frame but my mate says I should earth to engine does it matter?
Have you earthed the cdi as per wiring diagram ?
Posted: Sat Feb 11, 2023 2:47 pm
by boxofbits
Found the problem clip of needle has come off carb problem is I can't find it so no idea where's it's gone or how it would go miss as theres only a small slot at the front :oops:
