Spaco
cgt75b
Main scooter: lambretta
Hi
I’m maybe gonna bite the bullet and buy a complete new carb, my question is are the spaco carbs any good?
Would like some real world experience please.
Cgt75b.
gaz_powell
SI or PHBH type.
All SI carbs sre made by Spaco now, regardless if the are labelled Pinasco, BGM etc.
Ive use the 24E, 26E and 24G, with no problems at all on tuned and untuned P2 and T5.
Carb settings are the same, jets interchangeable with dellorto.
One thing i do is cut the air screw down and slot it so you can adjust easier with screwdriver instead of a socket.
Be warry about all the modifications you see on line.
Depending on what state of tune in most cases they dont need modification
If its the PHBH type icant comment.
cgt75b
Hi Gaz
Thanks for your reply. It was for an SI carb for me Rally, I’ve sorted it now mate,
Many thanks again 😎
gaz_powell
Glad you sorted... If you want a true rally look with spaco, BGM now make an air screw that is the same as the old dellys
    Users browsing this forum: Amazon [Bot] and 26 guests
