Tap
Posted: Thu Aug 19, 2021 4:22 pm
by cgt75b
Hi folks
Which is the best fuel tap for a standard Rally 200 please, I’m needing to change because of leakage.
Thanks for any pointers.
Cgt75b
Re: Tap
Posted: Thu Aug 19, 2021 9:55 pm
by gaz_powell
A genuine Piaggio, if you can find one.
If not SIP fast flow, that's what I've used for years with no issues.
Re: Tap
Posted: Fri Aug 20, 2021 9:50 am
by cgt75b
Ok Gaz cheers, any idea what the omg ones are like?
They seem a bit more readily available in this country mate?
The shipping costs from Germany are pretty s**t now tbh šŸ˜€
Re: Tap
Posted: Fri Aug 20, 2021 10:30 pm
by gaz_powell
Try Wasp Performance, that's where I get all my Vespa stuff.
I've used OMG FF on lambrettas for years and they have been spot on., still my tap of choice.
Gaz
Re: Tap
Posted: Sat Aug 21, 2021 11:53 am
by brynt
I have been using an OMG on my 125T.S, it is the same frame as a rally, for a over a year now with no problems
Re: Tap
Posted: Sat Aug 21, 2021 4:32 pm
by cgt75b
Thanks guys really appreciate your help šŸ˜Ž
Re: Tap
Posted: Sat Aug 21, 2021 5:00 pm
by cgt75b
Also having an issue with the carb leaking, would you guys use a little bit of sealant?
And if so what type please?
Cheers Cgt75b
