T5 tuning kit
Posted: Mon Aug 16, 2021 12:30 pm
by craigk
Hi all,
Are there any tuning kits for a T5 that work with the autolube?
Thanks in advance
Re: T5 tuning kit
Posted: Mon Aug 16, 2021 8:13 pm
by B-Race Tuning
I thought all the tuning kits work with autolube, it is only when you start messing with the carb that the autolube is disturbed/ affected. And a standard 24 SI/G carb can and does support approx 22hp+ using the T5 filter and convoluted hose to the frame.
Re: T5 tuning kit
Posted: Mon Aug 16, 2021 9:35 pm
by craigk
B-Race Tuning wrote: ↑Mon Aug 16, 2021 8:13 pm I thought all the tuning kits work with autolube, it is only when you start messing with the carb that the autolube is disturbed/ affected. And a standard 24 SI/G carb can and does support approx 22hp+ using the T5 filter and convoluted hose to the frame.
That's good to hear. The kits I've looked at don't actually mention if the autolube can be used. I want to keep the carb etc. as is, adding an exhaust/kit. Thanks, appreciate your reply
Re: T5 tuning kit
Posted: Tue Aug 17, 2021 12:09 am
by paul d
Many have different opinions on 2 stroke oil percentage but when I was using autolube I always added 1% into the tank on my kitted T5.
Re: T5 tuning kit
Posted: Tue Aug 17, 2021 2:58 pm
by craigk
paul d wrote: ↑Tue Aug 17, 2021 12:09 am Many have different opinions on 2 stroke oil percentage but when I was using autolube I always added 1% into the tank on my kitted T5.
Ok, so the autolube will still work, but as you've said (depending on the kit) I will need to add some to the tank too. At least that confirms I don't have to disconnect it totally. Which is what I was concerned about, none of the kits I've looked at mention it! Thanks Paul
