Pinasco Bull clutch
Smudge
Main scooter: Vespa GTS
I just can't get this clutch set up right. I get serious clutch drag, no slipping that I can feel though. Pinasco 251, 23/65, standard T5 gearbox.
I am as sure as I can be that everything was installed correctly and clearances measured with feeler gauges/micrometer. Everything in the engine is new except the gearbox which shows little if any wear any wear.
From minute 1 I've not really been happy...difficult 2nd to third but I did manage slightly less than 100 miles before wearing the plates out. The supplied plates were very slightly warped but I am not convinced enough to cause these probs. I put some SIP plates and steels in last week with DEX III and it is probably worse to be honest.
I've tried too many things to list here but all suggestions are welcome. I can't ride it as is and that is exactly what I want to be doing!
Thanks v much.
