Standard exhaust
Posted: Sat May 15, 2021 8:17 pm
by Lambretta67
Hi
Can I use a standard exhaust on a Indian G.P. 200 engine or do I have to use a big bore. I'm sure I read somewhere that the exhaust outlet is to big for a standard exhaust . Just want to make sure before I buy a new pipe.
Re: Standard exhaust
Posted: Sun May 16, 2021 5:48 pm
by Lamaddict
The standard size exhaust will probably make your standard engine run smoother better and quick. I think, I’m some cases we’ve been told bigger is better but it’s not always.
Posted: Mon May 17, 2021 5:51 pm
by Lambretta67
I thought the Indian barrel was designed for the big bore.
Posted: Mon May 17, 2021 7:25 pm
by db67
40mm SIL Clubman I believe.
Posted: Mon May 17, 2021 7:43 pm
by Lambretta67
So could I put a standard pipe on. The clubman pipes are too noisy for me.
Posted: Tue May 18, 2021 12:06 pm
by db67
As long as its suitable for a 200 ;)
Posted: Tue May 18, 2021 12:20 pm
by Lambretta67
Great .thanks. No more waking the neighbours when I go too work at 5am
Posted: Fri May 21, 2021 10:16 pm
by dirtyhandslopez
Find an exhaust gasket that matches the exhaust port(or even use a piece of paper to take a pattern) then put it onto the exhaust flange to see if it is the same. If it's not, get the file out and make it the same. You'll know you have no obstruction then.
Posted: Sat May 22, 2021 8:52 am
by Lambretta67
Cheers. Will give that a go. Going order standard pipe from scootopia
