starting a sil lambretta after 2 years
Posted: Fri Apr 30, 2021 11:25 pm
by JANFEATH
Hi, could anyone tell me how to go about starting my GP200 after it has been standing for 2 years.
Re: starting a sil lambretta after 2 years
Posted: Sat May 01, 2021 6:38 pm
by Stebbelaner
Drain all old fuel from tank and carb,check what state the inside of the carb is in and clean if necessary,check you've got a spark,add fresh fuel,allow time for the carb to fill and prod away on the kickstart - simples😉
Posted: Sat May 01, 2021 6:42 pm
by db67
Take the plug out, check you have a spark , drop a little bit of 2 stroke down the plug hole,kick it over a few times then put the plug back in, strip & clean the carb, drain any fuel out the tank & refill with fresh petrol & then you should be good to go for a start up👍
Posted: Sat May 01, 2021 11:54 pm
by JANFEATH
db67 wrote: ↑Sat May 01, 2021 6:42 pm Take the plug out, check you have a spark , drop a little bit of 2 stroke down the plug hole,kick it over a few times then put the plug back in, strip & clean the carb, drain any fuel out the tank & refill with fresh petrol & then you should be good to go for a start up👍
Thanks.
by JANFEATH
Stebbelaner wrote: ↑Sat May 01, 2021 6:38 pm Drain all old fuel from tank and carb,check what state the inside of the carb is in and clean if necessary,check you've got a spark,add fresh fuel,allow time for the carb to fill and prod away on the kickstart - simples😉
Thanks.
Posted: Thu May 13, 2021 7:32 am
by gaz_powell
Did you get it started??
