CHT (Vespa BGM 177)
Posted: Sun Apr 18, 2021 6:55 pm
Been perusing various forums to try & find out what’s a suitable ‘SAFE’ Cylinder Head Temperature but as usual the information put out is so varied & at times so vague I’m perplexed!
Scoot is;
Bgm 177
57mm Pinasco Racing crank
Drt Si 24/24 (55/160, Be3, AC 160, mj 125, both holes drilled out of filter)
Sip Road XL (swapping to Sip Road 3 on delivery)
Pinasco 1.6kg flywheel
Bgm super strong clutch
23/65 primary PX 125 box
Bgm ignition set out 24* static
Kytronik curve 7 (8* advance)
Casings matched to cylinder & carb bowl matched to carb etc...inlet 105*/60*, squish 1.1mm.
Bes9 plug
Temp sensor fitted into Cylinder Head not under plug or on cylinder stud!
I was after a more torquey Vespa (bit if a fat knacker you see) not a high RPM racer & torquey it is! I very recently had it dynoed at 16ps, a little low for the Sip road XL hence the swap to a Road 3 when it arrives. The scoot easily reaches 70mph(GPS) @7,000 rpm on the flat but that’s yer lot!
My main concern is CHT’s jump up from 250/275*f at approx. 5,000rpm to 340*f at approx 6-7,000rpm which makes my arse twitch & in turn ease off the throttle! Only given it a few WOT runs for approx 0.5 miles, I should be doing more now it’s run in but am hesitant not to seize.
My simplistic understanding is that 2 stroke motors run best at (CHT) 350-450*f which if correct would make me a happy chap however information (or opinion) is so varied I’m overly cautious.
WHAT IS THE SAFE ZONE?
Scoot is;
Bgm 177
Bes9 plug
