Sip speedo worm drive sensor cable settings
Posted: Sun Apr 18, 2021 4:26 pm
Just wondered if anyone had any of the settings for the following adjustments using the worm gear drive sensor cable :- I've set my tyre circumference to 1304 , this is after measuring 10 rotations of the wheel, drive ratio setting is at 0.7p & pulse setting is 3 , are these about right? just trying to fine tune it, thanks for any info
