Electronic ignitions
Posted: Wed Sep 23, 2020 4:36 pm
by Mrnice71
Whats everyones preferred choice of Ignitions these days ? Getting sick of failed low tensions and pick ups , looking at Varitronic , Vape or the Scootopia ones , any cons / pros ?
Re: Electronic ignitions
Posted: Wed Sep 23, 2020 4:50 pm
by cgt75b
Hi
Scootronics ignitions by Anthony Tambs are excellent quality, having said that I’ve had a Indian electronic ignition on for the past 20 years with not one bit of bother.
I’ll let you decide
Good luck with your decision making
Cgt75b 😎
Posted: Wed Sep 23, 2020 10:41 pm
by Toddy
Just fitted a vape what a quality kit can’t recommend as I’ve not ran it yet but quality wise excellent and had good reports off people who are running them
Posted: Wed Sep 23, 2020 11:39 pm
by Adam_Winstone
It wouldn't address the pickup failures but you could resolve the failed LT coil issue by changing to the Readspeed Lukas CDI, which uses the lighting coils to power the ignition. You could even make use of any existing LT failire stators.
I've run one of these for a couple of years and the system has proven very reliable.
Posted: Thu Sep 24, 2020 1:33 am
by paul d
Casatronic has been very reliable for me. Positives are reliability, easy starting, quality feel. Negatives are the flywheel holder could be stronger and in my case, brake light on at low revs means very poor headlight. led rear is essential!
Posted: Thu Sep 24, 2020 11:49 am
by Meds1
If you’ve still got the stator buy replacement LT coil and pickups from AT and repair as per his video.
Cheap and works,
Posted: Thu Sep 24, 2020 2:46 pm
by Mrnice71
Well thanks for all your replies guys , plenty of food for thought there .
Posted: Fri Sep 25, 2020 2:09 am
by Grumpy225
paul d wrote: ↑Thu Sep 24, 2020 1:33 am Casatronic has been very reliable for me. Positives are reliability, easy starting, quality feel. Negatives are the flywheel holder could be stronger and in my case, brake light on at low revs means very poor headlight. led rear is essential!
Could they have designed a worse flywheel holder?!
I'm right there with you here. Great kit right up to the holder. Haven't had any lighting issues. LED tail, halogen head. No dimming unless I hit the horn at idle.
