Carb choice?
Posted: Thu Aug 06, 2020 9:39 pm
I am running a Rapido 200 classic
With 42mm clubman, LI 150 box 15 46 sprockets. Indian webs crankshaft with new big end fitted. Running at 4%mixture.
At present it has a jettex 26mm carb.
I am spending more time bumping, cleaning the spark plug, stands, cdis than actually riding it.
When it does run i get about 56mph and a tank of fuel does about 50 miles. Its no pleasure at all riding it. I am never sure if it will start or if i will get home.
So i am going to change the carb and its booked in for a dyno session at chiselspeed.
Any suggestions on carb choice.
They have advised the polini 24mm evolution or a 25mm dellorto.
It was suggested i could go up with the carb to 28 or 30 but would need to change exhaust.
My musings at the moment are to stick with the 42 clubman. I am not sure if the crankshaft would cope with a bigger exhaust and carb. Or am i mistaken on that.
Is anyone using the polini 24mm carb? Any feedback opinions on it.
Thank you
Robbie
Thank you
Robbie
