RB200
Posted: Thu Jul 30, 2020 7:25 pm
by Chris Brad
Hi guys. A little help needed if poss. I’ve just got my new RB200 back. Been tuned and ported a little also. Running varitronic ignition at 17 degrees and Technigas pipe. I’ve decided to go with a Mikuni TMX35 but can’t find any jetting/needle info as to where to start off from for running in. I’ve got a full jet and needle kit with the carb. Up to now the carb is totally standard but don’t want to run it until it’s jetted somewhere near albeit on the safe side. Anybody got a starting point for jetting ?
Re: RB200
Posted: Thu Jul 30, 2020 8:38 pm
by coaster
I cant help you with the carb setup but the varitronic needs to be set something like 24 degrees so that it retards back to 17 at higher revs
Re: RB200
Posted: Thu Jul 30, 2020 9:37 pm
by Stoink
Not a 35 but maybe helpful:
I run a 32 tmx on my Rb20. Transfers opened up and matched to welded and ported case. Static timing at 17 btdc, B9EGV ngk plug. A.f. rayspeed expansion chamber.
Needle : 6FJ6 highest (richest) position
Needle jet: Q 0
Main : 330
Pilot: 27.5
Re: RB200
Posted: Thu Jul 30, 2020 9:48 pm
by Stoink
Needle jet is a 389 series. Also, strangely same carb in my stock rb22 with a similar set up but the needle in that is a 5FP17. Clear as mud..
Re: RB200
Posted: Fri Jul 31, 2020 1:08 am
by Grumpy225
Here's what I am running in my RB20 at 400' above seal level
Mikuni TMX 35
6.0 Slide
6en11 atomizer
55 needle-middle clip
295 main
22.5 pilot
Uni air filter
your mileage may vary
Re: RB200
Posted: Fri Jul 31, 2020 7:36 am
by Chris Brad
Thanks for the info guys. Lots to work from. Interesting to see so many different set ups. As 1 said “clear as mud”
