GT186 piston skirt question
Posted: Mon Jul 27, 2020 5:34 pm
I'm hoping someone can offer advice re. an unexpected problem with fitting an oversize piston to a rebored GT186 kit.
It's a 64.75mm Mitaka, so on its second rebore (it limped on with a massive ring gap for the past 18 months).
Problem is, the bottom of the piston skirt now hits the crankcase on the down stroke. I'm nonplussed. 60/110 crank. It ran fine with the earlier 64.5mm piston.
Has this happened to anyone else? What's the best way round it? A thicker base gasket/packer or taking a small amount off the skirt? What effect might it have on port timings?
Thanks in advance!
Thanks in advance!
