Page 1 of 2
Advice please
Posted: Sat May 23, 2020 12:32 pm
by jayteemmm
Hi
I am currently running in my RT195
Phbl 25 through airbox
Main 100
Aq268 Atomiser
D22 needle bottom clip
60 choke
53 idle
Running rich, seems to splutter when you get to your desired speed
Also running a Gori SS exhaust
Is this a revvy pipe?
I want good torque not speed
Any Information appreciated thx
Hohn
Re: Advice please
Posted: Sat May 23, 2020 2:07 pm
by Warkton Tornado No.1
I know very little about that range of Dell'Orto, but I suspect that atomiser is too large.
With any engine, the atomiser needs to be JUST big enough to deliver fuel @ WOT. Any bigger & fine tuning of the carburettor goes out of the window as the gap between it & the needle increases.
Anybody unsure of atomiser size (presuming they have the right type!) should remove the main jet & if it revs out clean, then it is too small. That said, I would bet that half the country's Lambrettas fitted with PH range carbs have an atomiser fitted that is too big :roll:
You don't mention slide size. I hope it's about a 45, but that's a guess.
As for the rest, I don't know about that needle, but the pilot looks too big (try a 50) & the main too small. I'd try 125 to start & come down if needs be.
But you really should try a smaller atomiser IMHO & check the slide size to get them sorted as fundamentals because of their major influences through the range. :) You'd be wasting your time with the rest until you have done that.....
Re: Advice please
Posted: Sat May 23, 2020 3:09 pm
by jayteemmm
Hi
The slide is 40 i think?
I have not changed it from new
It is std to what dellorto fit
Thx
Re: Advice please
Posted: Sat May 23, 2020 8:13 pm
by Grumpy225
jayteemmm wrote: ↑Sat May 23, 2020 12:32 pm Hi
Main 100
Aq268 Atomiser
60 choke
53 idle
Hohn
I’m running a similar set up but with a pod filter
Main 98
Pilot 50
Needle D22 3rd clip
Slide 40
BGM V2 exhaust
At 400’ ASL
Can’t comment on the exhaust you are running but your over all jetting is rich compared to mine and I’m not running through an air box. GPS 70mph max all day.
Re: Advice please
Posted: Sat May 23, 2020 11:11 pm
jayteemmm wrote: ↑Sat May 23, 2020 3:09 pm Hi
Thx
There's only one way to find out for certain ;)
As for the atomiser size, what I said still stands..... :P
Re: Advice please
Posted: Sun May 24, 2020 7:06 pm
by rainbowrunner
apart from exhaust, i,m on a clubman v4, same set up as me except for your clip position, my needle clips in middle, could try dropping your needle down a notch to lean it off a bit and try
Re: Advice please
Posted: Sun May 24, 2020 8:23 pm
by cgt75b
Have you looked through the carburettor jetting section for similar set ups?
Good luck.
Cgt75b
Re: Advice please
Posted: Fri Jun 05, 2020 2:19 am
by Davidsquaredson
The issue is the air box restricting airflow no? That’s a relatively big bore, carb, and exhaust. Correspondingly needs good airflow. I’d try a rubber elbow with a foam filter on it, removing the air box to make room. See how your jetting goes then.
Re: Advice please
Posted: Sun Jun 07, 2020 1:16 am
by kevspeed
Atomiser too big, Warkton Tornado had the answer straight off.
Re: Advice please
Posted: Sun Jun 07, 2020 10:01 am
by HxPaul
I've got a Casa 210 kit.Everything is exactly the same,apart from atomiser is an AQ266
MJ 102
IJ 47
needle is a D22 but on the top clip.
