Rear hub oil seal
Fudgy
Main scooter: Lambretta gp
Just replacing my rear hub oil seal. The new one seems to be really tight.I cant get it on without the lip peeling back or the spring popping out.
Mrnice71
Main scooter: Lambretta series 3
Rolf are the best , l couldn't get a cheap one to fit either and use lots of seal grease
Fudgy
Yeah.Just ordered a rolf one.
Cheers
Warm it up and cut a strip of plastic bottle to place around the inner race while you fit it.
Fudgy
Thanks will do when I get the new one.
Davidsquaredson
Main scooter: Early Eibar Jet 200
I was able to get the new type seal with the inner lip to fit by warming it up (used a hot air paint stripper on low setting and very carefully). I found the inner lip would flip out in one spot, so I took the thinnest feeler guage I had, and used it like a guide. As I pushed the greased seal on, I pulled the feeler guage out and it slipped past and onto the shaft properly.
Sent from my Pixel 2 using Tapatalk
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Fudgy
Cheers for your replies.
Just waiting for the rolf one to arrive.Just tried the cheapo one again couldn't get it to fit properly.
gaz_powell
Some bearings have very little or no chamfer on the edge which makes fitting the seal difficult.
I found plenty of grease and a small pick used carefully works. Some of the cheaper seals are not as flexible as Rolf.
Good luck
fluff34567
Careful using grease as some grease will degrade the rubber, best to use a dedicated seal grease.
Fudgy
Fitted the rolf one on today.Went on a lot better.
Cheers everyone.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 15 guests
