Mount
Posted: Tue May 05, 2020 6:40 pm
by cgt75b
Hi folks
Changing a rear shock mount easy or hard job?
Opinions please.
Cgt75b
Re: Mount
Posted: Tue May 05, 2020 8:41 pm
by Tractorman
If you mean the rear shock absorber it's just a matter of the two nuts, take the weight off the unit and pull it off evenly at both ends. Put some copper or normal grease on the mounting before you fit the new one.
Re: Mount
Posted: Wed May 06, 2020 5:49 am
by Toddy
Thgink he may mean the Mount on the Casing ? if so i believe its Pressed in ? never done it myselkf but heard it can be done ?
Re: Mount
Posted: Wed May 06, 2020 9:03 am
by cgt75b
Toddy wrote: ↑Wed May 06, 2020 5:49 am Thgink he may mean the Mount on the Casing ? if so i believe its Pressed in ? never done it myselkf but heard it can be done ?
That’s the one Toddy, so it sounds like it needs to be pressed out also?
Re: Mount
Posted: Wed May 06, 2020 9:59 am
by Toddy
cgt75b wrote: ↑Wed May 06, 2020 9:03 am
Yes it does ive seen somewhere on the web how someone did it cant find it though :(
Re: Mount
Posted: Thu May 07, 2020 1:40 pm
by Warkton Tornado No.1
I had a casing mount decide to come out of it's own accord. No real damage done as I was wearing brown corduroys @ the time. (It was in the 70's)
It was pressed back in far too easily, so was tapped & a big bolt fitted. We'd have probably used Loctite if the same were to occur today.
That all leads me to conclude that they are a press fit, but not a heavy interference fit & a big part of ensuring retention is the riveting of the head once fitted, though the fitting of a fastener is probably as good.
I hope that helps :)
Re: Mount
Posted: Thu May 07, 2020 5:59 pm
by cgt75b
Warkton Tornado No.1 wrote: ↑Thu May 07, 2020 1:40 pm I had a casing mount decide to come out of it's own accord. No real damage done as I was wearing brown corduroys @ the time. (It was in the 70's)
That is nearly as much help as the first reply lol
Re: Mount
Posted: Thu May 07, 2020 6:43 pm
by gaz_powell
I've just bought some brown boot cut cords.....
Re: Mount
Posted: Fri May 08, 2020 12:22 am
cgt75b wrote: ↑Tue May 05, 2020 6:40 pm Hi folks
Opinions please.
Cgt75b
cgt75b wrote: ↑Thu May 07, 2020 5:59 pm
Am I missing the point, somehow, in expressing my opinion as requested?
"That all leads me to conclude that they are a press fit, but not a heavy interference fit"
My apologies if my opinion was not quantified, but back then, I had no access to an hydraulic press with a pressure gauge.
Jeez! You lay down & I'll fan you!
Re: Mount
Posted: Fri May 08, 2020 7:00 am
by cgt75b
Thanks for all the replies.
