Inline hydraulic brake.
Posted: Mon Apr 20, 2020 6:13 pm
by 10 inch Terror
Hi all,
I’m finishing off a project I started in 2016. The original plan was to keep everything standard with a pepped up motor using a GT186. I was going to use the original front drum brake in a reverse pull set up. Anyway I’ve now decided to fit an in-line hydraulic brake. I’ve fitted and set up several of the Scootrs type external brake set ups but never the inline version. Are they any different to set up? I seem to remember reading that they can be a mission to bleed. Are there any pointers or things to watch out for? Any comments and tips would be greatly appreciated. Thanks in advance Pete.
Re: Inline hydraulic brake.
Posted: Tue Apr 21, 2020 8:47 am
by hendy
In line? Do you mean inboard? Or do you mean a remote master cylinder?
Posted: Tue Apr 21, 2020 10:15 am
by 10 inch Terror
hendy wrote: ↑Tue Apr 21, 2020 8:47 am In line? Do you mean inboard? Or do you mean a remote master cylinder?
Yeah, sorry, I meant inboard.
Posted: Tue Apr 21, 2020 10:55 am
by hendy
I've got one. No problem to bleed. I have a remote master cylinder behind the horncasting which I wouldn't do again as i find it a pain in the backside; that part was tricky to bleed, but i just "back-bleed" by injecting oil from the bottom end in a syringe which is much easier in my experience.
Posted: Tue Apr 21, 2020 3:28 pm
by 10 inch Terror
hendy wrote: ↑Tue Apr 21, 2020 10:55 am I've got one. No problem to bleed. I have a remote master cylinder behind the horncasting which I wouldn't do again as i find it a pain in the backside; that part was tricky to bleed, but i just "back-bleed" by injecting oil from the bottom end in a syringe which is much easier in my experience.
Nice one, I’ll give that a bash thanks Hendy.
