Rt195 setup
Posted: Fri Mar 27, 2020 8:21 pm
by jayteemmm
Hi
I am currently upgrading my lambretta series 3
Fitting:-
Rr195 kit
Gori exhaust/Scootopia 42mm clubman
25 dellorto
Bgm 120 AC stator
Do you have any ball park setups
ie:-
Gaskets for kit ( Base )
Carb setup ( jetting needle etc )
Timing
And any other help would be appreciated
Thank you
Re: Rt195 setup
Posted: Sat Mar 28, 2020 11:29 am
by nick b
timing 17degrees ,jetting all depends on where you live an altitude .i live in a warm climate and where a 125 jet was recomended i ended up with a 117 any way good luck i have had the kit for about 4 years .28 pwk ,bgm ignition ,ancillotti exhaust starts well ,pulls well sounds great
Re: Rt195 setup
Posted: Sat Mar 28, 2020 8:14 pm
by jayteemmm
Hi Nick
Great help i live in UK
Weather never too good wet most if the time lol
Thank you
Re: Rt195 setup
Posted: Sat Mar 28, 2020 8:36 pm
by nick b
iam from london but i have been living in southern spain for the last15+years good luck with the set up it took me a little while but once you are there it is a great system
Re: Rt195 setup
Posted: Sat Mar 28, 2020 9:35 pm
by rainbowrunner
bgm 195
25mm carb running through air box.
100 main
268 atomizer
choke jet 60
starter 50
BGM v4 clubman
Re: Rt195 setup
Posted: Tue Mar 31, 2020 2:11 pm
by corrado
rainbowrunner wrote: ↑Sat Mar 28, 2020 9:35 pm bgm 195
100 main
268 atomizer
choke jet 60
starter 50
BGM v4 clubman
Which needle? It's the 1/8 to 1/2 throttle that are the most difficult to get right because of several things over lapping, ie, needle, atomiser and slide. Most stick with the standard 40 slide as they're not cheap to replace. Commonly used needles on the PHBL are D22, 26 & 29.
Re: Rt195 setup
Posted: Tue Mar 31, 2020 7:56 pm
by rainbowrunner
corrado wrote: ↑Tue Mar 31, 2020 2:11 pm
100 main
268 atomizer
choke jet 60
starter 50
BGM v4 clubman
not sure on neadle, it was in the carb from new from readspead, same as slide, told them my set up and they jetted to suit, iv,e only changed the main jet when run in from a 102 to 100
Re: Rt195 setup
Posted: Fri Apr 10, 2020 8:19 pm
by jayteemmm
100 main
268 atomizer
choke jet 60
starter 50
BGM v4 clubman
Thank you for your information it is very helpful
Re: Rt195 setup
Posted: Sat Apr 11, 2020 6:13 pm
by garry inglis
with the rt 195 set the bottom edge of the transfer ports level with the crown of the piston at bdcentre depending what casing your fitting to it could be 1mm base packer or 1\2mm then check your squish with the head on you want 1.2 to 1.5 no more than 1,5
