Carb problem
Posted: Sun Mar 22, 2020 3:32 pm
Hi guys,
Need some help please.
Just finished restoring a 61 TV175 series 2, kept it all original except for 12 volt electronic ignition. (Couldn’t get the 4 pole points system working right).
Anyway I’m using the original 21mm BS7 carb and it’s not running right. Will start fine (with choke) and tick over when warm but seems to starve of fuel when I run it. When I open the throttle it kind of bogs down aNd cuts out. Will run better and is rideable with choke on, but if I flip the choke of within 50 yards 1/4 - 1/2 throttle it’s like it’s running out of fuel. Choke back on and it picks up again.
What should I be checking? Air screw is out 1/4 turn at the moment.
Thanks in advance
Steve
Thanks in advance
Steve
