LT Coil.
Posted: Mon Mar 09, 2020 2:50 pm
by YAMLAM
with the new trend not to use the LT coil (Ant Tambs CDi and Readspeed Lucas CDI )
could the LT coil not be replaced with an extra lighting coil to give a better output ?
i know feck all about electrickery and theres probabley a good reason why it cant be done :!:
Re: LT Coil.
Posted: Mon Mar 09, 2020 7:12 pm
by coaster
YAMLAM wrote: ↑Mon Mar 09, 2020 2:50 pm with the new trend not to use the LT coil (Ant Tambs CDi and Readspeed Lucas CDI )
Mr Tambs was talking about doing that a while back might also have been intending to have 6 coils but Ive not heard anything since.
Re: LT Coil.
Posted: Mon Mar 09, 2020 10:31 pm
by hendy
You absolutely could do just that, BUT the other 2 are in series to give 12v. So, you could put 3 in parallel and have 6v but with 50% more power.
Anthony tambs is developing a 3 phase stator which in my opinion is absolutely the best way to go. I'm not alone in this opinion though; try to find a modern bike that isn't 3 phase. As soon as they're available I'll be buying one.
Re: LT Coil.
Posted: Tue Mar 10, 2020 9:33 am
by HxPaul
If for some reason your external pick-up should pack up,you wont have an internal pick-up to switch to,because you wont have the LT coil.
Re: LT Coil.
Posted: Tue Mar 10, 2020 6:59 pm
by Adam_Winstone
I've been running a 5 lighting coil stator since before 5 Nations N.I. , with Readspeed Lukas. The lights are excellent.
Re: LT Coil.
Posted: Tue Mar 10, 2020 7:05 pm
by coaster
Adam_Winstone wrote: ↑Tue Mar 10, 2020 6:59 pm I've been running a 5 lighting coil stator since before 5 Nations N.I. , with Readspeed Lukas. The lights are excellent.
Did you just replace the LT coil with an additional lighting coil in series with the other 4?
Re: LT Coil.
Posted: Thu Mar 12, 2020 2:09 pm
by YAMLAM
tell us more ADAm
Re: LT Coil.
Posted: Wed Mar 18, 2020 8:13 pm
by Adam_Winstone
coaster wrote: ↑Tue Mar 10, 2020 7:05 pm
Yes, that's exactly what I did, nothing more complex than that.
I was out and about in Oxford on this bike today and was happy to have a horn that could be heard and lights that I could clearly see being reflected off the rear end of vehicles that I was following (in daylight).
Adam
Re: LT Coil.
Posted: Thu Mar 19, 2020 12:55 pm
by hendy
adam,
I'd expect that this would be better at low to mid rpm, but no difference at high rpm. Is that right or is it just better all the time?
