Getting steel ring out of break disk
Posted: Sat Jan 18, 2020 6:33 pm
by Davidsquaredson
Is there a trick to getting it out so I can drill the 3 holes slightly larger?
Thx
Re: Getting steel ring out of break disk
Posted: Sat Jan 18, 2020 6:49 pm
by Davidsquaredson
“Brake” autocorrects
Posted: Sat Jan 18, 2020 6:55 pm
by Davidsquaredson
Thinking about some more. Guessing tap the ring so one end is in a hole so I can get a pick under it?
Posted: Sat Jan 18, 2020 7:35 pm
by Muppet
a small bladed long flat screwdriver in one of the holes nearest one of the ends of the wire circlip; push against the clip through the hole just enough to get another thin bladed screwdriver in from the outside between the clip and the disc; once you’ve got that far you can lever the clip out
Posted: Sun Jan 19, 2020 12:08 am
by Davidsquaredson
Muppet wrote:a small bladed long flat screwdriver in one of the holes nearest one of the ends of the wire circlip; push against the clip through the hole just enough to get another thin bladed screwdriver in from the outside between the clip and the disc; once you’ve got that far you can lever the clip out
This worked. Thanks. Now onto the drilling.
Posted: Mon Jan 20, 2020 1:23 am
by Warkton Tornado No.1
The drilling oversize is not necessary if the three holes are cleaned up along with the pins & reassembled with copper type grease. Likewise, the anti-rattle circlip does precisely what it should. In fact, any spare discs that I have are those modified by well intentioned previous owners. The reason that Innocenti designed the product in the way they did is to prevent flutter of the disc & also to limit any tendency to drag on the static pad.
Reverse pull, the stoutest Bowden cable that you can fit (wound rectangular section outer) & sintered pads with careful assembly will result in a good front brake with lots of feel, not an on-off switch.
Posted: Tue Jan 28, 2020 4:46 pm
by Mrnice71
l wouldn't recommend drilling the holes out either , l know I did it !
Posted: Mon Feb 24, 2020 1:00 am
by rosscla
Getting it back in is a pig too
Posted: Mon Feb 24, 2020 2:26 pm
by warts
Another vote for not drilling out the holes.
I used a valve guide cleaning brush. Or maybe it was for cleaning some part of Diesel equipment. Anyway, a reasonably stiff wire "bristle" brush. If you can fit it in a drill so much the better.
