Page 1 of 2
Adapting a 42mm Clubman exhaust.
Posted: Sun Jan 12, 2020 4:26 pm
by Martin20
My LI 150, with Casa 185 kit, runs really well with a 42mm AF Clubman fitted, but I find it a tad too loud! I know loud pipes saves lives, but I am fed up of setting dogs off barking, folks turning around to see what's coming, etc.Has anyone adapted one to fit an end can/muffler, and if so, how, and did it quieten it down? Tia.
Re: Adapting a 42mm Clubman exhaust.
Posted: Sun Jan 19, 2020 9:44 pm
by dennis
bgm do a little end can for their exhaust (clubman type) perhaps you could adapt that.
Posted: Mon Jan 20, 2020 9:55 am
by Martin20
dennis wrote: ↑Sun Jan 19, 2020 9:44 pm bgm do a little end can for their exhaust (clubman type) perhaps you could adapt that.
Cheers! Will have a look at those.
Posted: Mon Jan 20, 2020 2:39 pm
by YAMLAM
any link ? cant find it in their catalogue.
Posted: Mon Jan 20, 2020 6:26 pm
by lozmondo
Here you go,
torbaylambretta.co.uk/BGM_Clubman_MufflerSilencer/p525714_20243127.aspx
Posted: Mon Jan 20, 2020 6:29 pm
by Martin20
YAMLAM wrote: ↑Mon Jan 20, 2020 2:39 pm any link ? cant find it in their catalogue.
Torbaylambretta have some for sale on their website. Have made enquiries re compatability with Af Rayspeed clubman, but it seems the AF flared tailpipe is an issue! 🤔
Posted: Mon Jan 20, 2020 7:24 pm
by wrecklessrobbie
I saw your post on Faceache and was also interested.
I was hoping you would get an answer for this.
The other problem i have, the tail pipe is angled upwards.
This causes black oily deposits to end up all over the back of the side panel.
I am sure im running too rich and a bit too much oil. But i prefer slightly rich than weak. And i should look at the jetting.
I did consider cutting it and angling it down.
Reading some threads on here though...it would seem that restricting the tail pipe with a smaller diameter can cause a heat build up and seizures.
Posted: Mon Jan 20, 2020 8:28 pm
by Martin20
wrecklessrobbie wrote: ↑Mon Jan 20, 2020 7:24 pm I saw your post on Faceache and was also interested.
I have emailed Torbaylambrettas today. They replied and suggested that the flared tail pipe of the AF Rayspeed clubman would be a problem. I have emailed back and asked for the dimensions of the bgm tail pipe to see if it would be feasible to modify an AF one. I will post their reply in due course.
Posted: Mon Jan 20, 2020 9:10 pm
by wrecklessrobbie
Thank you.
Posted: Mon Jan 20, 2020 11:40 pm
by Muttley McLadd
Would reducing your exhaust port timing cut the noise enough?
