Choke Cable for 30mm Dellorto on Lammy
Posted: Fri Jan 10, 2020 11:47 am
by immylam
Choke cable on S1 doesn't fit right. I heard someone sells a choke cable more suited to big carbs, does anyone know who makes/sells these? Thanks.
Re: Choke Cable for 30mm Dellorto on Lammy
Posted: Fri Jan 10, 2020 4:44 pm
by YAMLAM
Im Sure Knowledge used to make up cables .
Posted: Sat Jan 11, 2020 8:57 am
by gaz_powell
Yep Martin Leech did make them, not sure if he still is, if not Perry Lewis at Totally Scooters has them black ones advertised on Ebay
Posted: Sat Jan 11, 2020 10:56 am
by HxPaul
immylam wrote: ↑Fri Jan 10, 2020 11:47 am Choke cable on S1 doesn't fit right. I heard someone sells a choke cable more suited to big carbs, does anyone know who makes/sells these? Thanks.
Some choke cables are made too long to straight into the carb.They're supposed to have the solid 90 degree bend peice at the end.
Posted: Sun Jan 12, 2020 10:22 am
by HxPaul
Should read "some choke cables are made too long to GO straight into the carb".https://www.ebay.co.uk/itm/Lambretta-se ... SwWtZeBPSF
