Choke Cable for 30mm Dellorto on Lammy
immylam
Choke cable on S1 doesn't fit right. I heard someone sells a choke cable more suited to big carbs, does anyone know who makes/sells these? Thanks.
YAMLAM
Im Sure Knowledge used to make up cables .
win or lose have a booze
gaz_powell
Yep Martin Leech did make them, not sure if he still is, if not Perry Lewis at Totally Scooters has them black ones advertised on Ebay
HxPaul
immylam wrote: Fri Jan 10, 2020 11:47 am Choke cable on S1 doesn't fit right. I heard someone sells a choke cable more suited to big carbs, does anyone know who makes/sells these? Thanks.
Some choke cables are made too long to straight into the carb.They're supposed to have the solid 90 degree bend peice at the end.
HxPaul
Should read "some choke cables are made too long to GO straight into the carb".https://www.ebay.co.uk/itm/Lambretta-se ... SwWtZeBPSF
