? About wrist pin shims vs wider small end bearing
Posted: Sun Dec 29, 2019 6:13 pm
Hi,
I’ve got a new MEC 175 crank. The big end does not look shimmed. There is too large a gap between the small end bearing and the sides of the piston. I don’t have shims on hand but I do have a wider small end bearing. Assuming it’s within tolerance of the sides of the piston, is that sufficient? I’m just trying to think this through. Wouldn’t the piston still float because the gap between the short arm of the connecting rod and the piston walls remains too large? Whereas a shim fills the gap of both the needle bearing and the small end of the conrod stopping the piston from floating around?
