GS150 kickstart not returning
davla
I've recently bought a 1960 GS150 VS5 that hasn't been started for about 5 years. Before it was sat up it had a £1,900 engine rebuild at Retrospective Scooters so there shouldn't be too much wrong with it. One issue that I do have though is that the kick start doesn't fully return to the correct position after kicking over. Before I start pulling it apart, is it likely that the issue can be resolved from the outside or am I going to have to split the casing? Thanks in advance
    Users browsing this forum: Baidu [Spider] and 1 guest
