TSR Evo Tail can support
Norrie Bodge
Sat Nov 09, 2019 1:26 pm
essexgp wrote:
Fri Nov 08, 2019 5:32 pm
Norrie Bodge wrote:
Fri Nov 08, 2019 2:07 am
essexgp wrote:
Thu Nov 07, 2019 7:45 pm
Which SIP endcan do you use? as my Evo support bracket is fouling my GP side panel to
I haven’t used my TSR pipe yet m8 so not changed end can
But was informed it’s these ->. https://www.sip-scootershop.com/en/prod ... ng_20006ca
Thanks for that info but do you mean the SIP or the PM one? sorry to be thick
This one which in the description says same stud spacing as a PM
Scooterdude
Sat Nov 09, 2019 3:15 pm
I can confirm the cans sold by Chiselspeed as fitted to their exhaust range share the same stud spacing as the TSR evo.
holty
ebay user ID: amholt123
Main scooter: lambretta gp
Sat Nov 09, 2019 7:28 pm
you other option would be to alter the bracket, ive apapted one on my gp and its more or less under the end can, I do have a non standard exhaust so I had to make my own mounting on the engine, then a rubber bobbin, then cut and welded the bracket to fit between the two.
Norrie Bodge
Sun Nov 10, 2019 1:11 am
Any piccys mate?
Hughieboy
Main scooter: Lambretta Li S2 GT186
Sun Nov 10, 2019 6:08 pm
Thanks everyone.... photos of your bracket would be great!
essexgp
Sun Nov 10, 2019 6:15 pm
Thanks for the info
essexgp
Sun Nov 10, 2019 6:16 pm
Thanks again for the info
GTFOMWSC
ebay user ID: itsthewillo
Mon Nov 11, 2019 8:19 am
The trouble is we shouldn't have to do all this they cost enough money why should we end up fixing there crap.On mine also the 2 holes for the barrell studs were not far enough apart so i had to take my old JL manifold and clamp it together with the evo one and drill them through so it would fit,i'm told this has been common on a few of them as well.TBH it's bull we don't buy them to do all this they should fit right and to make a half attempt at a rear bracket that looks and fits sh*te just shows poor quality control(unfortunately same as the SIP road 2 vespa exhausts).
the man don't give a f@@k
Hughieboy
Mon Nov 11, 2019 11:44 pm
Amen to that!
