Lambretta Gear Oil
Posted: Fri Oct 25, 2019 5:53 pm
by operonalan
Anybody using ENI Rotrax 80W-90 gear oil
EP rated .... ? Is it applicable for use as lambretta gear oil ?
Re: Lambretta Gear Oil
Posted: Fri Oct 25, 2019 6:19 pm
by Muppet
EP = extreme pressure if you use it your clutch will slip
Posted: Sat Oct 26, 2019 3:08 am
by operonalan
Think I got that wrong it's Not EP rated the
ENI MP Rotrax 80W -90 is the one that is EP rated ...... One I referenced above ( without MP in reference ) in data sheet states for not excessive pressure conditions .........Got it from Chiselspeed so presume it's ok ... Just that I've never used it before and wondered if anyone had to give some feedback
Posted: Wed Oct 30, 2019 4:16 pm
by fluff34567
Check the GL rating, if its 4 or 5 and you have bronze bushes in your engine then forget it.
