New member
Posted: Mon Oct 21, 2019 3:21 pm
by Bothie
Hello
Thanks for the ad.....currently working through many components of an original 1962 Lambretta s3 that had been in storage in southern Italy for around 20 years. Main issue currently are the 4pole ignition system.
Re: New member
Posted: Mon Oct 21, 2019 4:44 pm
by firekdp
Bothie wrote: ↑Mon Oct 21, 2019 3:21 pm Main issue currently are the 4pole ignition system.
Hi mate and welcome. Is this the 1 hole brake switch system? If so what problems are you having with it?
Re: New member
Posted: Mon Oct 21, 2019 5:02 pm
by Bothie
Yes...1 hole brake switch I believe....When I started to explore the issue I found the insulation around the three wires from stator were totally perished and bare wired into the junction box/regulator. All globes blown.
Replaced the three wires, resoldered to a) points, b) condenser, c) heavier stator winding and yet still no spark.
Is it a faulty condenser? Faulty Coil? Bad earth?
Re: New member
Posted: Mon Oct 21, 2019 5:48 pm
by firekdp
Hard to say without testing them. But be aware that if the machine isn't fully wired up, you won't get a spark unless the stator pink is temporarily connected to a good earth.
Re: New member
Posted: Sun Nov 24, 2019 11:31 pm
by rosscla
Welcome aboard
