Page 1 of 2
Found this in gearbox oil...
Posted: Mon Sep 16, 2019 9:00 pm
by weedodger
Not long bought this lammy.. Not ridden yet... Decided to do oil change tonight... And change the chaincase gasket.... This popped out along wi the oil... Nice oil otherwise... Its metal.. Or alloy.. Not sure.. It pieces together like this.. Is about 8mm high and 6 to 8 mm wide... What the hell can it be.. Any ideas folks... I don't wanna ride the scoot on finding this....
Re: Found this in gearbox oil...
Posted: Mon Sep 16, 2019 9:30 pm
by weedodger
Posted: Mon Sep 16, 2019 9:33 pm
by weedodger
Pic 2 of debris in oil...
https://www.flickr.com/photos/184484635 ... res/2o3f90
Anyone any idea what this thing was... Is...
Posted: Tue Sep 17, 2019 5:46 am
by Toddy
Cant really tell how big they are ? are they Drive Chain Shells or part of a bearing ? Have you had a look inside yet ?
Posted: Tue Sep 17, 2019 5:53 am
by Scooterdude
Yes definitely looks like chain roller shells. Full strip down required.
Posted: Tue Sep 17, 2019 8:49 am
by weedodger
Toddy wrote: ↑Tue Sep 17, 2019 5:46 am Cant really tell how big they are ? are they Drive Chain Shells or part of a bearing ? Have you had a look inside yet ?
Hi mate.. About 8 to 10 mm high.. 7 or 8mm wide... Not looked inside yet.. Will do tonight ta
Posted: Tue Sep 17, 2019 8:50 am
by weedodger
Scooterdude wrote: ↑Tue Sep 17, 2019 5:53 am Yes definitely looks like chain roller shells. Full strip down required.
Barrel piston and head too... Or just the chaincase?
Posted: Tue Sep 17, 2019 10:23 am
by Bofs
Just chaincase, could be the thimble off your clutch, in that case it might be a simple case of replacing it.
Posted: Tue Sep 17, 2019 10:44 am
by weedodger
Bofs wrote: ↑Tue Sep 17, 2019 10:23 am Just chaincase, could be the thimble off your clutch, in that case it might be a simple case of replacing it.
Many thanks.. Will I spect today and get a few pics for advice.. Appreciate all the help thanks
Posted: Tue Sep 17, 2019 11:10 am
by Warkton Tornado No.1
It really does look like it is part of the duplex drive chain.
You should thoroughly inspect inside for more debris as well as check the existing chain.
If it has a Rolon chain fitted, do not use it again, would be my strong advice.
