Lambretta wiring problem need Advice
Posted: Thu Sep 05, 2019 9:36 am
So trying to wire up my sx- the loom is a new 12v one – it seems to have a black a purple a brown and green
So a SX switch and key ignition in headset
The brown and green black are easy enough—just match them up – but where does the purple go-
I read in a manual Purple from the main loom, to purple on the ignition switch, purple is an auxiliary power feed. But the ignition switch doesn’t have a purple it has a pink (earth) yellow I think is speedo bulb or side light a blue ( no idea what blue is) orange, brown, black, I cant get the lights to work at the front—if I add the purple with the 2 blacks ( one from loom and one from ignition switch) it seem to power the back light- any ideas
orange I've done to orange of the light switch (brown to brown black to black in head set)
