GP Clutch Plunger
Posted: Sat Aug 31, 2019 11:37 am
by Northener
For some reason at the base of the clutch shaft (sidecasing) my GP (bog standard Italian 150) has a circlip below the plunger yet the original parts manual shows none & i hear there shouldn't be one as the brass bush/plunger holds it in place in the sidecasing.
Any thoughts on this?
I had been having problems with the upper chain guide wearing at the edge (on my third one now) & a few pulling problems at top end now & again, does anyone think that this may have added to these problems (everything else fine & runs sound).
Just some confirmation on the circlip before i put her back together.
Re: GP Clutch Plunger
Posted: Sun Sep 01, 2019 3:35 pm
by vegansydney
Posted: Tue Sep 03, 2019 5:11 pm
by Northener
vegansydney wrote: ↑Sun Sep 01, 2019 3:35 pm Does this help?
Thanks, yes the first illustration is completely misleading, the second one originates from the original GP/DL parts catalogue (I've got a copy I dug out) & this is correct:
In the casing a washer goes up the top of the shaft then the 'E' clip (that is shown as the last bottom fitting to go on the shaft), then the plunger which sits & stays in place without a bottom circlip.
Found this too:
https://www.youtube.com/watch?v=W6qMQt2_wB0
