lml reedvale
Posted: Fri Aug 23, 2019 6:34 pm
by lammy666
just looked at my mates lml reed vale motor today because of a leak.
when i started it up there was what looked like (and smelt) like gear oil coming from the reed base ?.
i smelt the gear oil from the filling point on the engine and detected what i think smelt of petrol.
any idea what it could be.
Re: lml reedvale
Posted: Sun Sep 01, 2019 3:10 am
by Ginch
Usually means clutch side seal is gone when fuel and gear oil mix, often with white smoke present when starting up.
The crankcase is then pressurising the gearbox - if you block the clutch breather while it's running and the idle changes, that will confirm.
