Semi hydraulic set up
Posted: Fri Aug 23, 2019 5:16 pm
by psychedelicropcircle
The plunger on the remote master cylinder is not fully returning keeping the brake on slightly, is this Donald ducked? If so it’s the grimeca one where would I get one pronto style?
Re: Semi hydraulic set up
Posted: Fri Aug 23, 2019 11:46 pm
by hendy
Does it return ok when the cable is disconnected?
Posted: Sun Aug 25, 2019 7:31 pm
No It doesn’t return I’ve ordered 1 from Europe
Posted: Sun Aug 25, 2019 9:57 pm
by Muppet
the pin that the lever pivots on can corrode and stick which stops it from working smoothly makes it stick; take the two little circlips off remove the pin clean it up use copper slip on the pin and pivot and it might work
