exhaust ignitors?
Posted: Wed Jul 22, 2009 3:50 am
by Robi D
anyone ever set one up? how and what did you do? i would like to set one up on my hot rod themed ser. 1, i have a kit for cars but i think there is probably an easier way. i run a varitronic kit if it matters.
Re: exhaust ignitors?
Posted: Wed Jul 22, 2009 9:01 am
by cezeta
its as simple as having two coils and a push button to switch from one coil to the other. the idea being that if you kill ther ignition on part throttle then the gasses pass to the exhaust where you have a second plug which lights it.
the plug needs to be at the end of the pipe so the flames burn on the way out and not explode in the pipe.
my mate did it on a supercharged chevy imparla......it was crazy as it blew proper blow torch flames for 2-3 meters depending on revs :twisted:
