Sip Speedo
With all the add ons the sip Speedo is becoming quite expensive. Are they worth the cost or is a standard Speedo and fitting a temperature gauge in toolbox just as effective. Thanks
Grumpy225
- Main scooter: Gori200, rt195, ld150,rb20
I have a v1 in my dl and a v2 in my series 2.
Work great and more accurate than any stock speedo.
One bad thing to say about them; they need a SOLID power source or they will turn off, flicker, go dim and reset the clock on you.
I really wish they would convert or allow the option for the CHT in to an EGT. Way more useful.
Tractorman
- Main scooter: Lambretta li150 special
Not sure which version I have on the special but nothing changes on it when it goes off on tick over. It just comes back on again, same time and other data.
