Page 1 of 2
BGB stator output too low.
Posted: Mon Jul 29, 2019 7:19 pm
by Davidsquaredson
I've got a v1 bgm stator and matching flywheel on a jet200. My headlight is way too dim. I measured out put from stator to regulator and it is 6-7v at 1200 rpm and 10-11v when I'm revving it. Bike starts and rides great.
I thought it should be more like 14v.
What would cause this? One or more could failing?
Tx
David
Sent from my Pixel 2 using Tapatalk
Re: BGB stator output too low.
Posted: Mon Jul 29, 2019 10:57 pm
by hendy
weak magnets would cause that. Ac or DC?
Posted: Mon Jul 29, 2019 11:19 pm
by Davidsquaredson
AC. It's about 5 yrs old if I have to guess, but only a few thousand KMs use as I have several on the road.
Posted: Tue Jul 30, 2019 3:21 am
by Davidsquaredson
hendy wrote:weak magnets would cause that. Ac or DC?
I pulled the flywheel. It's a bgm with the solid magnet all the way around. It would hold a 19mm spanner hung from one end. But if I compare it to the scooters original SX taper flywheel, those magnets are much stronger.
I don't have another bgm fly wheel to compare against.
Posted: Tue Jul 30, 2019 8:01 am
by HxPaul
Do you have a cheap Indian flywheel,if so try that.
Posted: Tue Jul 30, 2019 12:15 pm
by Davidsquaredson
HxPaul wrote:Do you have a cheap Indian flywheel,if so try that.
I'm going to pull an AF Rayspeed flywheel off another scooter and try that.
Posted: Tue Jul 30, 2019 6:54 pm
by coaster
Were those readings taken without the lights on? The rason I ask is that you need a load present otherwise the regulator shorts the stator output to earth
Posted: Tue Jul 30, 2019 6:57 pm
by coaster
Its also worth paying particulat attention to your connections especially the earth tag on the stator itself. That tag is only rivited usually and they are often loose.
Posted: Tue Jul 30, 2019 9:41 pm
by Davidsquaredson
Hi, lights were on. But I put on an old Indian flywheel and lights were great. So cheers to the person who guessed weak magnets. I'll send SIP a note as that is a product fail.
Tonight I'll shim the pickup to match this flywheel and be done with it.
Tx again
Posted: Tue Jul 30, 2019 9:55 pm
by hendy
Or af will remagnetise for about a tenner.
