My 1980 Vespa P200e front tire wear...
Posted: Sat Jul 27, 2019 4:29 am
...is mostly on the left. Very noticeable.
The tire was on the front of the machine when I acquired it a few years ago. Don’t recall noticing abnormal wear on this tire then. I’ve since put 3500+/- miles on the Vespa with this tire on the front.
Is such uneven wear common?
Or is there some mechanical problem(s) I need to address?
The back tire that was on the Vespa when I bought it went bald last summer and was replaced with a newer one I had on hand. I don’t know whether it served as a front tire and was moved to the rear, or whether it spent its life on the rear wheel. The wear seemed pretty uniform across the entire tread.
Thanks!
Thanks!
