Gearbox Rebuild
Posted: Thu Jul 18, 2019 9:22 pm
by Choleric eric
<t>I am restoring and upgrading a 1962 Li125 . Fitted 150 cylinder bored out to 175. Old gearbox was shot so bought Indian 175 box. Changed all bearings and seals . All went well until I fitted the end plate and as soon as I started to tighten the bolts the gearbox became so tight it is almost impossible to turn. Have tried many times to fix the problem but without success. Any ideas please. Am I missing something obvious? I have run out of options!
Re: Gearbox Rebuild
Posted: Thu Jul 18, 2019 10:04 pm
by mick1
Had a similar problem. Turned out there was a slight cast burr in the bottom of the hole the xmas tree sits in. Cleaned the burr (2 minute job) and fitted perfectly.
All a bit strange as the engine was a 50 year old Italian casing which had several gearboxes fitted previously ?
Re: Gearbox Rebuild
Posted: Fri Jul 19, 2019 12:38 am
by rosscla
Welcome aboard.
Try fitting the clutch centre and nut and tighten down to see what happens. This can pull the cluster up into the bearing.
Re: Gearbox Rebuild
Posted: Fri Jul 19, 2019 6:23 am
by hendy
Have you fitted new bearing track in end plate?
If so, make sure it's pressed fully home.
