Running in
Posted: Mon Jul 01, 2019 11:49 pm
There's lots of advice out there on 'running in' you see ads with 'run in carefully' etc all over the place but what does this actually mean ?
There seems to be a received wisdom that you do X speed for Y miles / hours the gradually build up and at some magical figure it is 'run in'.
This seems to be more important on cast barrels than plated but some of the plated kits come with quite detailed guidance on extensive 'running in' periods whereas others are a few heat cycles and 'ride it like you stole it'.
You'll also see people who recommend various regimes including varying speed / revs / not labouring the engine etc.
Now I understand that you need to take it easy for a bit on a newly built top end or engine while things bed in and I understand that it's probably important on a newly bored / plated barrel that you need to let the rings flat off the peaks on the barrel hone but is there any evidence or science about how long this should take?
What is the actual purpose off running in ?
For plated barrels for example -
How long does it take to run in new rings on a previously run kit?
How long do you need to run in a new piston?
For iron barrels -
Are these values any different?
Is there any published evidence in either case that running in adds to engine longevity?
For iron barrels -
