Joint
Posted: Wed Jun 05, 2019 1:42 pm
by cgt75b
Hi dudes
Which petrol tap joint are you guys using, I'm sick to death of them breaking or vibrating themselves to bits!
Many thanks for looking
Options/opinions welcomed.
Cgt75b.
Re: Joint
Posted: Wed Jun 05, 2019 4:11 pm
by HxPaul
https://www.ebay.co.uk/itm/Petrol-Tap-B ... SwKlFcyET4
Just using a standard one like this,never had a problem.
Re: Joint
Posted: Thu Jun 06, 2019 2:28 pm
by cgt75b
Yep used those before more often than not they snap.
Thanks for that though.
I'm currently using one I bought from a well known dealer which as always has fallen to bit ffs.
Cgt75b.
Re: Joint
Posted: Thu Jun 06, 2019 4:19 pm
by Mrnice71
MB scooters do one in stainless , but if your fuel tap is not straight they will break . Guess your using a big carb on the left hand side
Re: Joint
Posted: Thu Jun 06, 2019 5:05 pm
by cgt75b
Mrnice71 wrote: ↑Thu Jun 06, 2019 4:19 pm MB scooters do one in stainless , but if your fuel tap is not straight they will break . Guess your using a big carb on the left hand side
I wouldn't call a 25 mil dellorto a big carb!
But thanks all the same.
Cgt75b.
Re: Joint
Posted: Fri Jun 07, 2019 12:07 am
by bazza3004
Ive never had one break. Is everything else free and easy to tirn.
Re: Joint
Posted: Fri Jun 07, 2019 7:56 am
by cgt75b
bazza3004 wrote: ↑Fri Jun 07, 2019 12:07 am Ive never had one break. Is everything else free and easy to tirn.
It is now bazza thanks, I've just ordered a universal joint we will see how that gets on!
Watch this space
Appreciate the help.
Cgt75b
Re: Joint
Posted: Sun Jun 09, 2019 6:46 am
by Grumpy225
Same here. Many carb set ups with various extreme angles, never had one break. I have some original italian ones still in use on my dl with a phbh carb.
Is there something going on with the pins you’re using? Maybe they are too big and cause the joint to bind?
