Exhausts joint clamp totally disappeard
garry inglis
The exhaust clamp has snapped off somehow so changed break shoes and cleaned every thing while I was in there all done so whent for test ride ImageImage
cgt75b
Main scooter: lambretta
And was the scooter ok?
garry inglis
Yes I thought the db killer in the exhaust was loose coming back from kelso and when I checked the whole silencer was moving back and forward but luckily the water pump stopped it from going to far back to come apart all sorted now
cgt75b
Ah right ok, great that you've got it sorted.
I did lejog a number of years ago with lads on gts's and they were having problems back then with exhaust gaskets or slip joints I think,
Is this a common problem with them? You would of thought these kinds of recurring problems would be ironed out by the manufacturer.
Cgt75b.
