Page 1 of 4
Lambretta crank induction with Malossi MHR 221
Posted: Sun May 19, 2019 9:38 am
by mick1
My aim was to do a reed crank induction on my Lambretta. Thinking it was a waste using a Lambretta barrel (the carb' inlet needing to be blocked off) i decided to use a Vespa 221 MHR, which was cheaper than most Lambretta kits :D
I had a spare Spanish 150 casing out of a 76' Li and a solid series 2 Spanish frame for the new engine to go in. I also had some MK 2 Vijay forks that i wanted to use. This was my basis for the build but there was plenty of bits still to buy.
I started this just before Christmas 2018 when i approached a local engineer with regards to the welding and machining required. He said he needed the crank and a reed block would be easier than making our own, these were duly purchased (58x60 crank) from AF and an MB shorty.
With my brand new MHR kit, reed block, crank and casing i met with the engineer. It was decided to skim the face of the casing then weld a new aluminium "ring" on the end. This was to be 20mm+. The reed block was more of a challenge. We discussed the size of the opening we were going to create and clearance issues with the frame and other engine parts (cable adjuster block for one).
In the new year we had it something like:
https://www.flickr.com/photos/156231260 ... ed-public/
Will continue later....trying to show photos rather than links........any ideas ?
Re: Lambretta crank induction with Malossi MHR 221
Posted: Sun May 19, 2019 1:25 pm
by wrecklessrobbie
Download Tapatalk Mick.
You can then load them off that onto here.
Its simple...must be....I can do it :D
Posted: Mon May 20, 2019 10:47 pm
by Grumpy225
I still host photos on scoot.net/gallery/bbs and that seems to work
A few years ago I started on that same build. Grafting a Malossi 210 on a LI150 case with a case inducted reed block. Just got as far as welding the block up and some rough cuts. After that it got retired to the shelf of shame and traded off. Hope you get farther along than I did!
Posted: Tue May 21, 2019 3:19 am
by Norrie Bodge
I use https://postimages.org/
Really easy to add photos
Posted: Tue May 21, 2019 3:22 am
by Norrie Bodge
Norrie Bodge wrote: ↑Tue May 21, 2019 3:19 am I use https://postimages.org/
When it’s uploaded your photo, Just click on the option upload to forums & then paste it here
Posted: Tue May 21, 2019 4:25 am
by tony172
Watching with interest. I love this type of conversion!
Congratulations on having the b@11@x to step away from the norm
Posted: Tue May 21, 2019 7:34 am
by mick1
Thanks for the replies, managed to sort the photo's:
ImageIMG_20181228_102230 by mick leaf, on Flickr
ImageIMG_20190107_134622 by mick leaf, on Flickr
ImageIMG_20190109_152530 by mick leaf, on Flickr
ImageIMG_20190109_152609 by mick leaf, on Flickr
ImageIMG_20190119_112139 by mick leaf, on Flickr
Imageraptor engine build by mick leaf, on Flickr
Managed to put the top end together without any dramas but had a problem with the gearbox :(
I'd purchased the cheapest gearbox i could find (GP) but when tightening the end plate the box kept on seizing. After trying different shims and spacers i noticed a slight casting burr on the casing under the xmas tree. 30 seconds with the dremel and the box turned smoothly. Trying to solve the tightening issue i'd fitted the Spanish G/box back in.......and decided to leave it. I've also got an AF cassette clutch, GT chain tensioner and a modified side Li side casing to work the GP style clutch. The carb' i'm initially using is the cheapest i could find....a pwk copy, 34mm with powerjet.....£18 :D ........by the way, i'm from Yorkshire :o
Posted: Tue May 21, 2019 8:43 am
by nellyboyo
Brilliant effort ...no frame clearance issues ???
Posted: Tue May 21, 2019 1:59 pm
by mick1
nellyboyo wrote: ↑Tue May 21, 2019 8:43 am Brilliant effort ...no frame clearance issues ???
Wait for it.........
Posted: Tue May 21, 2019 6:01 pm
by sean brady scooters
interesting topic ,and great to see ..good luck with it bud and let me know if you want that crank chamfering to suit :)
