rt 195
Posted: Sun Apr 28, 2019 8:46 pm
by lammy666
any suggestions on the type of clutch i should use on my new build rt195.
i will be running a box exhaust and a 25mm dellorto through the air box/
thanks in advance
Re: rt 195
Posted: Sun Apr 28, 2019 9:04 pm
by jayteemmm
Hi
I am currently building a similar setup
I also want to put a GP crank in place of the existing LI crank
Re: rt 195
Posted: Sun Apr 28, 2019 10:31 pm
by rosscla
I've just put a Readspeed one in my Rt 225 it's very grippy. Standard clutch was slipping on the compression just on the kickstart.
It's about 45£ for the corks, steels and springs. Done 300K running in in the last week or so and seems fine.
Re: rt 195
Posted: Mon Apr 29, 2019 11:37 am
by garry inglis
surflex plates with mb springs more than you need
Re: rt 195
Posted: Mon Apr 29, 2019 1:39 pm
by Burnside
Readspeed 5 plate, running them in my GT186 and GT200, been good as gold for several k miles
Re: rt 195
Posted: Mon Apr 29, 2019 8:45 pm
by lammy666
cheers for the info guys
Re: rt 195
Posted: Mon Apr 29, 2019 9:40 pm
by Mrnice71
A 4 plate should be fine with that set up , the scootopia clutch plates are good with MB springs and rough the steel plates up a bit and putoline SAE 90 gear oil should hold
Re: rt 195
Posted: Tue Apr 30, 2019 6:57 pm
by lozmondo
Done 1000,s of miles on BGM plates and MB springs on RT195, bgm pipe and 30mm carb
Re: rt 195
Posted: Tue Apr 30, 2019 7:13 pm
by HxPaul
I've got a Casa 185 kit.I use a 4 plate clutch with standard springs,never a problem.
