AF Clutch
Arfur
Playstation gamer tag: hulkascooby
Guys I’ve got an AF clutch on my rebuilt engine. It’s never been run everything is brand new. Was doing some finishing touches yesterday and noticed that the clutch arm will not move seems to be jammed.
It was fine when the scoot was put away for the winter (time beat me to finish before the winter set in) now it won’t engage. Any ideas?
garry inglis
Pull the clutch lever in and kick it over a couple of times should free it up
Arfur
Cheers Buddy I'll give it a try at the weekend and let you know
bazza3004
Do you mean the lever on the case is solid amd won't move?
garry inglis
No your lever on your headset the plates will have stuck together and this can free them up
Arfur
sorted thanks guys
