Squish too large?
Posted: Sat Mar 09, 2019 3:43 pm
Hi,
I’ve just fitted a LML 5 port 150 kit to my 125 LML with an FA Italia head to suit.
The piston is level with the bottom of the transfer ports at BDC and almost at the top of the bore at TDC, which seems normal. With a 0.3mm (supplied) head gasket fitted the squish is about 3.5mm, which I think is far too much. The roof of the combustion chamber to the gasket face is about 2.8mm, which also seems a lot. Any thoughts/solutions? Ta
