Reed petals for LML engine
3narf
Main scooter: 1966 Vespa 150 standard (VBB2T
Hi, does anyone know where I can get the Boyesen 2-stage reeds for a standard LML engine? I believe they're KDX80 or RD350 ones.
PS there seems to be no way of registering for the LML forum... :roll:
a.lo.v2
Main scooter: sx 200
I have been looking myself. I think the part number is 605. the only ones I have seen are on American Ebay.
3narf
Thanks, any snippet of information helps! Standard RD350 ones would be OK but I want to cut out the bridge piece if possible and I'd need the 2-stage ones for that.
3narf
Hi, obtained the reeds from the USA (607 or 608 I think they are) and did the mod yesterday including removing the bridge from the intake. I also drilled the 'heart' under the air filter.
I have a bit of a blockage at the moment because it's dying on the throttle (as if it's cold and needs choke) but it was doing that before so it's not related to the reed valve. I should probably have sorted it first before doing the mod...
