Series 2
Posted: Fri Dec 14, 2018 2:14 pm
by cgt75b
Hi peeps
Anyone using a removable panel hook on a series 2? Which supposedly makes it easier getting the back wheel if punctured.
Thoughts/experiences
Thanks in advance.
Re: Series 2
Posted: Sun Dec 16, 2018 9:58 am
by Jeff T
No but mine is just cut off, not by me but never had any issues
Re: Series 2
Posted: Sun Dec 16, 2018 3:02 pm
by db67
Yes, that's the easiest option , you just need to remove between about 10 or 15 centimetres of metal from the outer bracket "hook" ,its a bit of trail & error until you can get the wheel off, done this on both my series 1's & its a big help ;)
Re: Series 2
Posted: Sun Dec 16, 2018 4:14 pm
by db67
db67 wrote: ↑Sun Dec 16, 2018 3:02 pm Yes, that's the easiest option , you just need to remove about 10 or 15 mm of metal from the outer bracket "hook" ,its a bit of trail & error until you can get the wheel off, done this on both my series 1's & its a big help ;)
Re: Series 2
Posted: Sun Dec 16, 2018 4:15 pm
by db67
T
Re: Series 2
Posted: Sun Dec 16, 2018 4:43 pm
by cgt75b
I'm a little confused now! Is this with the removable hook or not?
Many thanks.
Cgt75b.
Re: Series 2
Posted: Sun Dec 16, 2018 5:27 pm
by db67
No, not as standard but you can buy a panel bracket kit off eBay that allows you to bolt/unbolt the bracket but you obviously have to remove the original bracket first to use one of these, or you could just modify the original one to make it removal ;)
